I have problem watching twitter embedded videos. I got this error message: "This browser does not support video playback."
Here is an example
I have Firefox version 43.0.
Parto
  • 15,647
laplasz
  • 141
You should -
  1. make sure that gstreamer1.0-libav plugin is installed
  2. then in firefox address bar go about:config, search mediasource & enable media.mediasource.webm.enabled & media.mediasource.enabled
That should allow playback on twitter as long as the 1st. 2 mentioned below are not enabled or you enable all 3
If you want full coverage in Firefox as seen in https://www.youtube.com/html5, (all 6), then in about:config in addition to above search media & enable media.fragmented-mp4.exposed & media.fragmented-mp4.ffmpeg.enabled & needed to not break facebook media.fragmented-mp4.gmp.enabled
As they say proof is in the pudding -
doug
  • 17,212
You can use Pepper Flash in firefox. Pepper Flash is basically Chrome's Flash API. Chrome has this API installed by default (You might notice this when you have a fresh install of Windows/Linux and Chrome doesn't need to install flash while other browsers do).
Here are the steps:
  1. Open terminal by clicking the Ubuntu logo, the Super key or press Ctrl+Alt+T
  2. Type or copy in
sudo add-apt-repository ppa:nilarimogard/webupd8
sudo apt-get update
sudo apt-get install freshplayerplugin
  1. Install google-chrome from it's website or use the chromium way in the link below (The reason you install Google Chrome is for the freshplayerplugin to recognize the Pepper Flash in Chrome and load it into Firefox)
Open firefox and go to about:plugins. This is what you should get (notice the flash version): about:plugins
Uninstall Linux Flash by doing
sudo apt-get purge flashplugin-installer adobe-flashplugin adobe-flash-properties-gtk adobe-flash-properties-kde
Source: Can I use Chrome's Pepper Flash with Firefox?
I have just updated Firefox to version 43.0 and now the video is supported and playable.
laplasz
  • 141
This problem is definitely add-on/extension related.
Restarting with add-ons disabled in Firefox safe mode resolves the issue. Note that simply disabling or removing ad block plus does not work. How: https://support.mozilla.org/en-US/kb/troubleshoot-firefox-issues-using-safe-mode
In my case I had flashblock installed and disabling it from firefox addon manager did the trick. as seen below:
flashblock-disable
Sources: https://support.mozilla.org/en-US/kb/troubleshoot-firefox-issues-using-safe-mode
Testing
Elder Geek
  • 36,752
