I'm used to working on GVim, but I want to make most of vim+tmux too. Therefore I have decided to switch to vim. But in vim the cursor style does not change depending on the mode.
I use zsh and gnome terminal.
I have tried this answer: How to make cursor change from thin line to block based on normal or insert mode in Console Vim on Gnome Terminal
if has("autocmd")
au InsertEnter * silent execute "!gconftool-2 --type string --set /apps/gnome-terminal/profiles/Default/cursor_shape ibeam"
au InsertLeave * silent execute "!gconftool-2 --type string --set /apps/gnome-terminal/profiles/Default/cursor_shape block"
au VimLeave * silent execute "!gconftool-2 --type string --set /apps/gnome-terminal/profiles/Default/cursor_shape ibeam"
endif
but it changes the cursor globally.
I have also tried this plugin, but it hasn't worked either. (How can I check if the plugin is working?)
