16
While reading the git introductory material, I read a piece that brought this question to mind.
How do I use the Terminal to find out what my Default Text Editor is?
Are there a General Commands that I can use to find this out?
In Ubuntu, there is a generic editor command which is set by the Debian alternatives system.
If you do:
editor foobar.txt
the file will be opened using the original editor e.g. vim, nano which is prioritized as editor currently.
You can check the details with:
update-alternatives --display editor
To set a new editor as editor:
sudo update-alternatives --config editor
Also note that bash checks some environment variables for tasks related to it, to be exact bash checks VISUAL, EDITOR one after another. If unset, bash defaults to nano (unless an editor you've installed has overridden this).
Some processes spawned from bash check these environment variables too.
murchu27
  • 157
heemayl
  • 93,925
12
The default editor is as defined by the EDITOR, or VISUAL, environment variable(s).
The default editor is vi if neither were defined. Add
export EDITOR="/bin/nano"
to your ~/.bashrc file to set, for example, nano as your default editor.
To see if the environment variable is set, you can use
printenv | grep EDITOR
or
set | grep EDITOR
One can dereference the value of the named environment variable by prefixing it with a "$"
$ echo $EDITOR
or
$ echo $VISUAL
Doug Smythies
  • 16,146
There is actually git var -l which allows you to list the variables, including GIT_EDITOR variable. Here's mine (private info is unset of course):
$ git var -l
user.name=*****
user.email=****
GIT_COMMITTER_IDENT=****
GIT_AUTHOR_IDENT=****
GIT_EDITOR=editor
GIT_PAGER=pager
As heemayl already pointed out, editor command is the one set by /etc/alternatives/editor. In my case, that's nano (which I assume is default for Ubuntu, because I don't remember consciously making an effort to change my default editor).
But on other systems other than Ubuntu (or I should say which have no Debian's alternatives system) , there is no editor. Let's, however read up the man git:
GIT_EDITOR
This environment variable overrides $EDITOR and $VISUAL. It is used by several Git commands when, on interactive mode, an editor is to be launched. See also git-var(1) and the core.editor option in git- config(1).
And if we look through git-var it tells us
The order of preference is the $GIT_EDITOR environment variable, then core.editor configuration, then $VISUAL, then $EDITOR, and then the default chosen at compile time, which is usually vi.
Thus it is a mere perculiarity of Ubuntu that it has Debian's alternatives system. On other systems which don't have Debian's alternatives systems it would default to vi
