I am running a rails app inside of a docker container but trying to reach it from a browser the browser shows ERR_CONNECTION_REFUSED . when running docker ps I get
a086ed5a6c4a        rails                       "bash"                   3 days ago          Up About an hour    0.0.0.0:3000->3000/tcp                                                            rails
then when running docker inspect rails I see the gateway is "Gateway": "172.17.0.1"
when I try and ping 172.17.0.1 it works but if I ping 172.17.0.1:3000 it doesn't work.
when I try nmap -p 3000 172.17.0.1 I get
Starting Nmap 6.40 ( http://nmap.org ) at 2015-12-12 15:27 PST
Nmap scan report for 172.17.0.1
Host is up (0.000047s latency).
PORT     STATE  SERVICE
3000/tcp closed ppp
running sudo netstat -tulpn I get the following.
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 127.0.0.1:5940          0.0.0.0:*               LISTEN      1900/teamviewerd
tcp        0      0 127.0.1.1:53            0.0.0.0:*               LISTEN      5965/dnsmasq
tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      1195/dnsmasq
tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      2910/cupsd
tcp6       0      0 :::5858                 :::*                    LISTEN      4693/docker-proxy
tcp6       0      0 :::4200                 :::*                    LISTEN      4629/docker-proxy
tcp6       0      0 :::6379                 :::*                    LISTEN      4423/docker-proxy
tcp6       0      0 :::8080                 :::*                    LISTEN      4665/docker-proxy
tcp6       0      0 ::1:53                  :::*                    LISTEN      1195/dnsmasq
tcp6       0      0 ::1:631                 :::*                    LISTEN      2910/cupsd
tcp6       0      0 :::5432                 :::*                    LISTEN      4540/docker-proxy
tcp6       0      0 :::3000                 :::*                    LISTEN      3099/docker-proxy
tcp6       0      0 :::3001                 :::*                    LISTEN      4700/docker-proxy
tcp6       0      0 :::3002                 :::*                    LISTEN      6521/docker-proxy
tcp6       0      0 :::7357                 :::*                    LISTEN      4610/docker-proxy
udp        0      0 0.0.0.0:27824           0.0.0.0:*                           6091/dhclient
udp        0      0 0.0.0.0:53717           0.0.0.0:*                           569/avahi-daemon: r
udp        0      0 0.0.0.0:5353            0.0.0.0:*                           3206/chrome
udp        0      0 0.0.0.0:5353            0.0.0.0:*                           569/avahi-daemon: r
udp        0      0 0.0.0.0:5699            0.0.0.0:*                           5961/dhclient
udp        0      0 127.0.1.1:53            0.0.0.0:*                           5965/dnsmasq
udp        0      0 127.0.0.1:53            0.0.0.0:*                           1195/dnsmasq
udp        0      0 0.0.0.0:68              0.0.0.0:*                           6091/dhclient
udp        0      0 0.0.0.0:68              0.0.0.0:*                           5961/dhclient
udp        0      0 0.0.0.0:631             0.0.0.0:*                           1336/cups-browsed
udp6       0      0 :::53862                :::*                                5961/dhclient
udp6       0      0 :::5353                 :::*                                569/avahi-daemon: r
udp6       0      0 ::1:53                  :::*                                1195/dnsmasq
udp6       0      0 :::59093                :::*                                569/avahi-daemon: r
udp6       0      0 :::26992                :::*                                6091/dhclient
I had to bind to 0.0.0.0 when running rails server. So I used rails server -b 0.0.0.0 as explained in the answer here. https://stackoverflow.com/questions/34246254/cant-access-docker-container
The most likely explanation is that Rails isn't actually running in the container. In particular, the output of docker ps shows that the command running in the container is bash. That would mean that unless you have started it manually inside the container, Rails isn't running.
