'tar' literally means tape archive and stores and extracts files from a tape (or disk) archive. tar supports a large number of compression programs such as gzip, bzip2, lzip, lzma, lzop, xz and traditional compress
tar commands should begin with a function such as
[-] A --catenate --concatenate | c --create | d --diff --compare |
--delete | r --append | t --list | --test-label | u --update | x
--extract --get [options] [pathname ...]
the -a option can be used to autodetect the compression desired from the suffix (extension) of the file being created. tar should autodetect the compression type and act accordingly on extraction without a need for specific information. It will only fall back on the suffix for type determination if the signature check fails. For much much more on tar issue the command man tar and to learn more about tar compression specifically, see: https://www.gnu.org/software/tar/manual/html_section/tar_69.html
There are a number of options that can modify the results. tar allows for the addition to, and removal The extension in no way indicates file type. For instance I've seen image files from a Windows system with an extension of .jpg that were actually .gif. To find out the file type open a terminal with Ctrl Alt T navigate to the directory with the file in question and issue the command file filename Here's an example of output from a gzip compressed file:
$ file wireless-info.tar.gz
wireless-info.tar.gz: gzip compressed data, from Unix, last modified: Thu Apr 23 07:45:20 2015
Changing the extension in no way changes the output of file making it a trustworthy way of determining filetype even on files you don't own and have no notes on. Here's an example after renaming the previous file and removing the .gz...
wireless-info.tar: gzip compressed data, from Unix, last modified: Thu Apr 23 07:45:20 2015
For more on file and how it works issue the command man file
Sources: Experience & https://www.gnu.org/software/tar/manual/html_section/tar_69.html
