12
On Ubuntu 12.04, I have been happily using VMware Workstation 6. Then, one fine day, this error occurred when starting a VM:
Could not open /dev/vmmon: No such file or directory.
Please make sure that the kernel module `vmmon' is loaded.
Failed to initialize monitor device.
I'm not sure of the reason, but it could be, purely speculative, due to upgrading the Nvidia driver (it was akin to a visit to the dentist's office, so please do not tell me to mess around again with the graphic driver.)
In pursuit of a resolution, I updated to VMware Workstation 12 using the GUI installer.
gksudo bash xxxxx.bundle
I assume it was smart enough to uninstall the older version before proceeding to installing the new version. All is good, except the same problem above occured when I tried to start a virtual machine. Indeed, as counselled, I could not find the file or directory /dev/vmmon in my system (this is also true before reinstalling to the newer version.)
Following another wise counsel, I tried:
sudo vmware-modconfig --console --install-all
The full output (lest I be downvoted for lack of providing detail) is such:
Stopping VMware services:
   VMware Authentication Daemon                                        done
   VM communication interface socket family                            done
   Virtual machine communication interface                             done
   Virtual machine monitor                                             done
   Blocking file system                                                done
Using kernel build system.
make: Entering directory `/tmp/modconfig-ha12A3/vmmon-only'
/usr/bin/make -C /lib/modules/3.13.0-49-generic/build/include/..    SUBDIRS=$PWD SRCROOT=$PWD/. \
  MODULEBUILDDIR= modules
make[1]: Entering directory `/usr/src/linux-headers-3.13.0-49-generic'
  CC [M]  /tmp/modconfig-ha12A3/vmmon-only/linux/driver.o
  CC [M]  /tmp/modconfig-ha12A3/vmmon-only/linux/driverLog.o
  CC [M]  /tmp/modconfig-ha12A3/vmmon-only/linux/hostif.o
  CC [M]  /tmp/modconfig-ha12A3/vmmon-only/common/apic.o
  CC [M]  /tmp/modconfig-ha12A3/vmmon-only/common/comport.o
  CC [M]  /tmp/modconfig-ha12A3/vmmon-only/common/cpuid.o
  CC [M]  /tmp/modconfig-ha12A3/vmmon-only/common/hashFunc.o
  CC [M]  /tmp/modconfig-ha12A3/vmmon-only/common/memtrack.o
  CC [M]  /tmp/modconfig-ha12A3/vmmon-only/common/phystrack.o
  CC [M]  /tmp/modconfig-ha12A3/vmmon-only/common/task.o
  CC [M]  /tmp/modconfig-ha12A3/vmmon-only/common/vmx86.o
  CC [M]  /tmp/modconfig-ha12A3/vmmon-only/vmcore/moduleloop.o
/tmp/modconfig-ha12A3/vmmon-only/linux/driver.c: In function   ‘LinuxDriver_Ioctl’:
/tmp/modconfig-ha12A3/vmmon-only/linux/driver.c:1983: warning: the frame size of 1280 bytes is larger than 1024 bytes
  LD [M]  /tmp/modconfig-ha12A3/vmmon-only/vmmon.o
  Building modules, stage 2.
  MODPOST 1 modules
WARNING: "mcount" [/tmp/modconfig-ha12A3/vmmon-only/vmmon.ko] undefined!
  CC      /tmp/modconfig-ha12A3/vmmon-only/vmmon.mod.o
  LD [M]  /tmp/modconfig-ha12A3/vmmon-only/vmmon.ko
make[1]: Leaving directory `/usr/src/linux-headers-3.13.0-49-generic'
/usr/bin/make -C $PWD SRCROOT=$PWD/. \
      MODULEBUILDDIR= postbuild
make[1]: Entering directory `/tmp/modconfig-ha12A3/vmmon-only'
make[1]: `postbuild' is up to date.
make[1]: Leaving directory `/tmp/modconfig-ha12A3/vmmon-only'
cp -f vmmon.ko ./../vmmon.o
make: Leaving directory `/tmp/modconfig-ha12A3/vmmon-only'
make: Entering directory `/tmp/modconfig-ha12A3/vmnet-only'
  CC [M]  /tmp/modconfig-ha12A3/vmnet-only/driver.o
  CC [M]  /tmp/modconfig-ha12A3/vmnet-only/hub.o
  CC [M]  /tmp/modconfig-ha12A3/vmnet-only/userif.o
  CC [M]  /tmp/modconfig-ha12A3/vmnet-only/netif.o
  CC [M]  /tmp/modconfig-ha12A3/vmnet-only/bridge.o
  CC [M]  /tmp/modconfig-ha12A3/vmnet-only/procfs.o
  CC [M]  /tmp/modconfig-ha12A3/vmnet-only/smac_compat.o
  CC [M]  /tmp/modconfig-ha12A3/vmnet-only/smac.o
  CC [M]  /tmp/modconfig-ha12A3/vmnet-only/vnetEvent.o
  CC [M]  /tmp/modconfig-ha12A3/vmnet-only/vnetUserListener.o
  LD [M]  /tmp/modconfig-ha12A3/vmnet-only/vmnet.o
  MODPOST 1 modules
WARNING: "mcount" [/tmp/modconfig-ha12A3/vmnet-only/vmnet.ko] undefined!
  CC      /tmp/modconfig-ha12A3/vmnet-only/vmnet.mod.o
  LD [M]  /tmp/modconfig-ha12A3/vmnet-only/vmnet.ko
make[1]: Entering directory `/tmp/modconfig-ha12A3/vmnet-only'
make[1]: Leaving directory `/tmp/modconfig-ha12A3/vmnet-only'
cp -f vmnet.ko ./../vmnet.o
make: Leaving directory `/tmp/modconfig-ha12A3/vmnet-only'
Starting VMware services:
   Virtual machine monitor                                            failed
   Virtual ethernet                                                   failed
Unable to start services
I see a couple of warning messages but no errors, hence baffling indeed the case of the missing and unloadable vmmon.
Following other counsels:
>> sudo /etc/init.d/vmware restart
>> sudo modprobe vmmon
FATAL: Error inserting vmmon (/lib/modules/3.13.0-49-generic/misc/vmmon.ko): Unknown symbol in module, or unknown parameter (see dmesg)
Thy wise counsel I desperately seeketh.
ng0323
  • 121
5 Answers5
16
This command fixed it for me
abu_bua
  • 11,313
Disabling Secure Boot from UEFI is a poor answer but it's the official answer on the VMWare forum.
I had a similar issue when installing VirtualBox and managed to resolve my VMWare issue using the same method. This allows me to keep secure boot enabled and also use VMWare.
The issue is that the vmware kernel module is not signed so fails to be loaded when secure boot is enabled. However you can "self sign" the module which is what I did for both VMWare workstation and VirtualBox.
  1. Go to this forum post : https://forums.virtualbox.org/viewtopic.php?f=7&t=77363&start=15
  2. Go to the post by Fayce66 on 6 May 2016, 08:37
  3. In each command replace the kernel module "vboxdrv" (virtualbox module name) with "vmmon" (vmware module name)
  4. You might have to do all the commands again for kernel module "vmnet" (vmware network module)
These steps worked for me. I am able to keep secure boot enabled and use VMWare Workstation.
Abid
  • 81
It's possible that your problem with VMware Workstation 12 is that...
On Linux host with secure mode enabled, it is not allowed to load any unsigned drivers. Due to this, VMware drivers, such as vmmon and vmnet, are not able to be loaded which prevents virtual machine to power on.
To fix this without turning off secure boot, you can do the following in a terminal to self-sign the drivers:
  1. Generate a key pair using the openssl to sign vmmon and vmnet modules:
    openssl req -new -x509 -newkey rsa:2048 -keyout MOK.priv -outform DER -out MOK.der -nodes -days 36500 -subj "/CN=VMware/"
    (Replace MOK with the name of the file you want for the key.)
  2. Sign the modules using the generated key by running these commands:
    sudo /usr/src/linux-headers-`uname -r`/scripts/sign-file sha256 ./MOK.priv ./MOK.der $(modinfo -n vmmon)
    sudo /usr/src/linux-headers-`uname -r`/scripts/sign-file sha256 ./MOK.priv ./MOK.der $(modinfo -n vmnet)
  3. Import the public key to the system's MOK list by running this command:
    sudo mokutil --import MOK.der
  4. Confirm a password for this MOK enrollment request.
  5. Reboot your machine. Follow the instructions to complete the enrollment from the UEFI console.
Cited from this VMWare article: https://kb.vmware.com/kb/2146460
jtpereyda
  • 2,115
  • 20
EriC
  • 351
Just disable Secure Boot from UEFI options.
https://kb.vmware.com/selfservice/microsites/search.do?language=en_US&cmd=displayKC&externalId=2103112
I build an automated shell script to help download, extract and build the VMWARE vmnet and vmmon files. Running this should fix the issue.
Try it here -> vmware-host-modules-builder-cli and create an issue if you encounter any problems.
