I'm trying to install Steam on the laptop my son is getting for christmas (running Ubuntu 14.04.3 LTS), however when I try to run Steam for the first time (via the "Steam" desktop icon it creates), a Terminal window appears and I am told:
Steam needs to install these additional packages:
libgl1-mesa-dri:i386, libgl1-mesa-glx:i386, libc6:i386
Entering the password does its thing, then I am told:
Reading package lists... Done
Building dependency tree
libgl1-mesa-glx:i386 : Depends: libglapi-mesa:i386 (= 10.1.3-0ubuntu0.5)
unity-control-center : Depends: libcheese-gtk23 (>= 3.4.0) but it is not going to be installed
Depends: libcheese7 (>= 3.0.1) but it is not going to be installed
N: Ignoring file 'steam.list.disable' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
N: Ignoring file 'google-chrome.list.disable' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
N: Ignoring file 'webupd8team-java-trusty.list.disable' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
I press "Enter" and am told in a pop-up dialog box:
You are missing the following 32-bit libraries, and Steam may not run:
libGL.so.1
I have followed the answer found here, however it had no effect...
Any help would be appreciated.
