13
Let's say I have 3 files in a particular directory: abc.txt, aww.txt, ant.txt
If I do: cat a (and press tab to see options) terminal will display the 3 file names: abc.txt, aww.txt, ant.txt
Is there any way to select the nth result rather than typing, by specifying the index number in the results the terminal displayed?
something like: cat a2 to get the second file (aww.txt)?
muru
  • 207,228
samsamara
  • 407
Assuming you are using bash, either add the following to your ~/.bashrc:
bind '"\e[6~": menu-complete'
bind '"\e[5~": menu-complete-backward'
Or to change the defaults for all programs that use the readline completion library, not just bash, create the file ~/.inputrc containing:
$include /etc/inputrc
Now when you open a new terminal, you can press:
  • TAB as normal to see available completions.
  • Pg Dn to select the first completion or change to the next one.
  • Pg Up to select the last completion or change to the previous one.
  • Alt+n Pg Dn to select the nth completion or move forward n completions.
So for your example type Pg DnPg Dn or Alt+2Pg Dn to get the second file aww.txt.
Martin Thornton
  • 5,996
  • 32
  • 43
