I have ubuntu 15.10 running as a virtual machine I would like to install and use SDL2, I followed this process What is the general procedure to install development libraries in Ubuntu? as well as the instruction for Ubuntu from here:
I got no errors or anything when installing SDL2 but somehow it just won't compile with the following error:
Can't locate SDL.pm in @INC (you may need to install the SDL module)...
which means I didn't install SDL2 correctly somehow :/
Has anyone got an idea how I can check if it is installed properly?
Ueffes
  • 63
Easiest way is to just install by apt-get...
If you just want the libraries:
sudo apt-get install libsdl2-2.0
On Bionic or newer:
sudo apt-get install libsdl2-2.0-0
If you want to do development:
sudo apt-get install libsdl2-dev
Simon Sudler
  • 4,111
