I am trying to install libvirt 1.2.7 from sources on Ubuntu 12.04 (64bit) LTS. In order to compile libvirt, libdevmapper-dev is required. I a getting following error while installing libdevmapper-dev
# apt-get install libdevmapper-dev
Reading package lists... Done
Building dependency tree
libdevmapper-dev : Depends: libdevmapper1.02.1 (= 2:1.02.48-4ubuntu7.4) but 2:1.02.90-2ubuntu1 is to be installed
Depends: libdevmapper-event1.02.1 (= 2:1.02.48-4ubuntu7.4) but 2:1.02.90-2ubuntu1 is to be installed
I have also tried installation with aptitude but it asks for removal several other necessary libraries e.g. liblvm2cmd2.02. Moreover I can not afford to upgrade system to later ubuntu versions.
apt-cache policy gives following output.
# apt-cache policy libdevmapper1.02.1
libdevmapper1.02.1:
Installed: 2:1.02.90-2ubuntu1
Candidate: 2:1.02.90-2ubuntu1
Version table:
*** 2:1.02.90-2ubuntu1 0
100 /var/lib/dpkg/status
2:1.02.48-4ubuntu7.4 0
500 http://us.archive.ubuntu.com/ubuntu/ precise-updates/main amd64 Packages
2:1.02.48-4ubuntu7 0
500 http://us.archive.ubuntu.com/ubuntu/ precise/main amd64 Packages
How can I resolve this dependency?
