I have Ubuntu 15.10 installed. I have also installed LAMP using the Ubuntu wiki help page. I then proceeded to set up Moodle via the web page installation. I hit a road block when I got
Moodle requires the json PHP extension.
Please install or enable the json extension.
With the link above, I have tried installing, whilst LAMP was still installed, only PHP5 (libapache2-mod-php5) -- and of course restarting the apache2 service. The problem is in the the /etc/php5/mods-available folder, no json.ini file appears. When I type in terminal sudo php5 -m, json is not a module running. However if I attempt to remove PHP5, it shows before I confirm the removal that the package php5-json will go.
The question I have is how do I get the json extension if I don't have it already, or if I do have it (and it's placed somewhere else) how do I enable it?
EDIT: output of apt-cache policy php5-json
php5-json:
Installed: 1.3.7-1
Candidate: 1.3.7-1
Version table:
*** 1.3.7-1 0
500 http://nz.archive.ubuntu.com/ubuntu/ wily/main amd64 Packages
100 /var/lib/dpkg/status
Tried sudo apt-get install --reinstall php5-json but still missing file.
