Does there exist some panel or desktop applet or X application to show various logs of my system, as they scroll? I know I can open multiple terminals and then tail -f all the logfiles I am interested in. But that has to be done either with a special script or manually as well as positioning the terminal windows. Lots of work each time. So I was interested in a more or less complete solution. Rather large panel applets would also be viable with multiple monitors or 4K display. I am using Lubuntu at the moment, but the DE can be any.
Asked
Active
Viewed 59 times
You could install indicator-script-runner and create a "script" which tails the relevant log file. To run the script, select from the indicator menu and a terminal is launched, executing your script.
For each log file you want to tail, create a separate script.
Bernmeister
- 1,149
