I have problems with my notebook's wifi (Intel Corporation Wireless 7265 (rev 59) on Ubuntu 14.04 (3.13.0-68-generic). Signal is shown often low (for no reason and same notebooks in Windows have much better performance) even though I am standing next to the router.
A friend of mine installed on his notebook (identical model brand etc...) Debian and it works perfectly. I asked him to send me modinfo iwlwifi output.
It seems to be, he has a newer driver and kernel version. Then I used diff to compare to mine. Should I try to install the new module (driver) on my current kernel or try to use newer kernel, which is not provided yet by the Ubuntu repositories? I do not want to play around with the kernel without any advice from experienced users and mess up my system.
1c1
< filename:
/lib/modules/3.13.0-68-generic/kernel/drivers/net/wireless/iwlwifi/iwlwifi.ko
> filename: /lib/modules/3.16.0-4-amd64/kernel/drivers/net/wireless/iwlwifi/iwlwifi.ko
3c3
< author: Copyright(c) 2003-2013 Intel Corporation
> author: Copyright(c) 2003- 2014 Intel Corporation
18,21c18,24
< firmware: iwlwifi-7265-7.ucode
< firmware: iwlwifi-3160-7.ucode
< firmware: iwlwifi-7260-7.ucode
< srcversion: A45BAACCAD263355629DB7A
> firmware: iwlwifi-7265-9.ucode
> firmware: iwlwifi-3160-9.ucode
> firmware: iwlwifi-7260-9.ucode
> firmware: iwlwifi-8000-8.ucode
> srcversion: 3E4DCD8265C8E43DCA7B0EA
> alias: pci:v00008086d000024F4svsd00000030bcsci
> alias: pci:v00008086d000024F3svsd00000010bcsci
300,303c303
< vermagic: 3.13.0-68-generic SMP mod_unload modversions
< signer: Magrathea: Glacier signing key
< sig_key: xxx
< sig_hashalgo: sha512
> vermagic: 3.16.0-4-amd64 SMP mod_unload modversions
309c309
< parm: wd_disable:Disable stuck queue watchdog timer 0=system default, 1=disable, 2=enable (default: 0) (int)
> parm: wd_disable:Disable stuck queue watchdog timer 0=system default, 1=disable (default: 1) (int)
310a311
> parm: uapsd_disable:disable U-APSD functionality (default: Y) (bool)
314a316
> parm: fw_monitor:firmware monitor - to debug FW (default: false - needs lots of memory) (bool)
