I have downloaded the online installer from Steam's website. However, steam doesn't want to work after the installation process. I'm running Ubuntu 15.10 64bit. How can I get steam to work?
Edit1:
I have tried the following command: sudo apt-get install steam
Steam still does not work.
Edit2:
More details as requested.
I have tried the following command in the terminal: steam
This is the output:
Running Steam on ubuntu 15.10 64-bit
STEAM_RUNTIME is enabled automatically
[2015-12-06 21:38:07] Startup - updater built Nov  9 2015 18:23:22
SteamUpdateUI: An X Error occurred
X Error of failed request:  BadValue (integer parameter out of range for operation)
Image of the error
GSM-S
  • 624
Run these commands in terminal :
32Bit
mv $HOME/.steam/ubuntu12_32/steam-runtime/i386/usr/lib/i386-linux-gnu/libstdc++.so.6 $HOME/.steam/ubuntu12_32/steam-runtime/i386/usr/lib/i386-linux-gnu/libstdc++.so.6.bak
64bit
mv $HOME/.steam/ubuntu12_32/steam-runtime/amd64/usr/lib/x86_64-linux-gnu/libstdc++.so.6 $HOME/.steam/ubuntu12_32/steam-runtime/amd64/usr/lib/x86_64-linux-gnu/libstdc++.so.6.bak
This solution may have solved steam errors like yours in other posts, e.g. this Post.
As it has not been marked as solved yet, please tell me if this works or not.
Neil
  • 4,585
Try installing it directly from the Ubuntu Software Center app.
Some info on this page as well, though may be out of date. But it has references to some resources that can help.
https://wiki.ubuntu.com/Valve
