I have a Z170 Gaming K6 motherboard with a killer ethernet 2400. I have just installed Ubuntu but I'm not getting any internet even though I connected it with a wired connection to my router. I have looked around and found this post
Is there any way to install Atheros e2400 drivers?
and this link
but I get stuck on the first few steps.
sudo apt-get source linux-image-$(uname-r)`
gives me the following error
E: You must put some 'source' URIs in you sources.list
Here is what happens when I use lspci:
sudo lspci -vvnn | grep Ehternet
06:00.0 Ethernet controller [0200]L Qualcomm Atheros Device [1969:e0a1] (rev 10)
and lshw gives me
sudo lshw -C network
*-network UNCLAIMED
description: Ethernet controller
product: Qualcomm Atheros
vendor: Qualcomm Atheros
physical id: 0
bus info: pci@0000:06:00.0
version: 10
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msi msix bus_master cap_list
configuration: latency=0
resources: memory: df100000-df13ffff ioport:c000(size=128)
Any help would be much appreciated! Thanks!
ifconfig tells me
Link encap: local loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 SCope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:528 errors:0 dropped:0 overruns:0 frame:0
TX packets:528 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:41936 (41.9 KB) TX bytes:41936 (41.9 KB)
