I want to convert a chm file to a pdf file. Calibre's command ebook-convert ebook-convert 1.chm 1.pdf only converts the first 7 pages of the chm file into a pdf file, while the chm file has much more pages. How can I convert the whole chm file into a pdf file? Thanks.
Tim
  • 26,107
You probably want to use chm2pdf from the universe repository.
To install chm2pdf in Ubuntu 14.04-18.04 open the terminal and type:
sudo apt-get install chm2pdf
You then run the command like this:
chm2pdf OPTIONS FILENAME.CHM FILENAME.PDF
Note that as OPTIONS, you must at least specify either
  • --book (structured output: headings, chapters, ...),
  • --webpage (unstructured, but page breaks between different documents/URLs in the CHM file), or
  • --continuous (unstructured output)
For more information, see man chm2pdf.
karel
  • 122,292
  • 133
  • 301
  • 332
Byte Commander
  • 110,243
Try a different online converter. Zamzar is useful if the CHM file is under 100MB.
http://www.zamzar.com/convert/chm-to-pdf/
Another option is to use chm2pdf. To do so, use the following commands in a terminal session...
chm2pdf foo.chm foo.pdf
That second command assumes that your CHM file is named 'foo.chm', so adjust that as appropriate.
Source: http://www.ubuntugeek.com/how-to-convert-chm-files-into-pdf-files-in-ubuntu.html
Aren
  • 483
