I want to install the Oracle Virtualbox by adding a repository with the apt-add-repository command. In order to gain experience in using the apt commands, I would not like to directly modify the sources.list file. I understand I also need to add the key. I found in the Ubuntu manual the following command to insert :
sudo sh -c "echo 'deb http://download.virtualbox.org/virtualbox/debian '$(lsb_release -cs)' contrib non-free' > /etc/apt/sources.list.d/virtualbox.list" && wget -q http://download.virtualbox.org/virtualbox/debian/oracle_vbox.asc -O- | sudo apt-key add - && sudo apt-get update && sudo apt-get install virtualbox-5.0
Unfortunately I do not understand what it does. Can anyone "dismantle" this command and give me the separate list of the commands I should use?
hg8
  • 13,582
piscvau
  • 119
When you encounter commands that you don't understand, use manual pages.
This big command can be separated in three main parts :
  1. Adding VirtualBox repository to the system
  2. Register Oracle public keys
  3. Installing Oracle VirtualBox
Let's breack up each part :
sh -c
If you type man sh you will get :
-c               Read commands from the command_string operand
                 instead of from the standard input.  Special
                 parameter 0 will be set from the command_name operand
                 and the positional parameters ($1, $2, etc.)
                 set from the remaining argument operands.
Now :
is the address where the VirtualBox packages are located.
When you run the command lsb_release -cs it will output your Ubuntu version :
$ lsb_release -cs
trusty
> is a redirection operator. It writes the previous output to the following file :
When you run
it will output in your terminal :
Running
will write the line :
to the /etc/apt/sources.list.d/virtualbox.list file instead of giving a terminal output.
Note : This is not the advised method to use. It may lead to duplicate entries when running twice.
The recommended way to add the VirtualBox repository to the system is add-apt-repository :
sudo add-apt-repository "deb http://download.virtualbox.org/virtualbox/debian trusty contrib"
Replace trusty with your current Ubuntu version.
man wget output :
DESCRIPTION
       GNU Wget is a free utility for non-interactive download of files from
       the Web
-q
       --quiet
           Turn off Wget's output.
With this command you download the VirtualBox public key...
...and register it to the system (What does the “-” mean?):
sudo apt-key add -
sudo apt-get update
man apt-get output :
   update
       update is used to resynchronize the package index files from their
       sources. The indexes of available packages are fetched from the
       location(s) specified in /etc/apt/sources.list.
And finally sudo apt-get install virtualbox-5.0 installs the virtualbox-5.0 package.
If you need additional clarification, do not hesitate to ask.
More information you can find in the answer from @takkat.
There is a list of all separated commands necessary to install VirtualBox.
hg8
  • 13,582
