I'm on trusty (14.04.2 LTS). current version of openssh=6.6 (OpenSSH_6.6.1p1 Ubuntu-2ubuntu2.3, OpenSSL 1.0.1f 6 Jan 2014)
Was told to upgrade to openssh=6.9 or greater.
Why does the ssh daemon now not properly start/stop via upstart?
Here is what I did...
Downloaded 6.9 tarball (openssh-6.9p1.tar.gz).
processed thusly (all as root):
cd openssh-6.9p1
./configure --prefix=/usr --sysconfdir=/etc/ssh --with-pam --libexecdir=/usr/lib/openssh
make
stop ssh  ;(stopped properly)
make install
Hangs during upstart launch...
start ssh  ;(control-c to escape)
I can see the NEW daemon is running, and I can actually ssh into the box. The new version nows...
ssh -V
OpenSSH_6.9p1, OpenSSL 1.0.1f 6 Jan 2014
Also tried:
initctl --system start ssh
Rebooted. ssh into box OK. Can see service running via: ps aux | grep ssh
The process ID in /var/run/sshd.pid matches what I saw in the above ps.
stop ssh  ; hangs - control-c to escape.
I actually went thru the trouble of downloading a debian 6.9 package and extracting the contents. The upstart script in there is the same as what version 6.6 is using (I've not mucked w/ it).
Current /etc/init/ssh.conf content:
# ssh - OpenBSD Secure Shell server
# The OpenSSH server provides secure shell access to the system.
description "OpenSSH server"
start on runlevel [2345]
stop on runlevel [!2345]
respawn
respawn limit 10 5
umask 022
env SSH_SIGSTOP=1
expect stop
# 'sshd -D' leaks stderr and confuses things in conjunction with 'console log'
console none
pre-start script
    test -x /usr/sbin/sshd || { stop; exit 0; }
    test -e /etc/ssh/sshd_not_to_be_run && { stop; exit 0; }
    mkdir -p -m0755 /var/run/sshd
end script
# if you used to set SSHD_OPTS in /etc/default/ssh, you can change the
# 'exec' line here instead
exec /usr/sbin/sshd -D
Jack
