Whenever the focus is on a text edit element, the key combination ctrl+alt+b brings up a weird on screen keyboard:
screenshot
I wanted to remove this binding (or delete the program), but I can find neither! As you can see in the image, the OSK is not Florence nor Onboard, nor any I could find online. A reverse google image throws no results.
I'm using Ubuntu 14.04.3 LTS, with openbox as window manager, and no DE.
The way to solve the issue but keep fcitx:
sudo vim /usr/share/fcitx/addon/fcitx-vk.conf
add to the file
Enable=false
logout, login again
Zanna
  • 72,312
petertc
  • 203
I had the same problem. Probably it's caused by fctix, which is some software, which supports input methods. For some reason, I couldn't successfully kill this process from terminal. I found it in graphical system monitor and killed the process from GUI. After that, while typing Ctrl+alt+B, weird keyboard wasn't displayed anymore. You can also try to remove this software.
Instruction showing how to remove fctix can be found here: http://installion.co.uk/ubuntu/precise/universe/f/fcitx/uninstall/index.html
Uninstalling:
sudo apt-get remove --auto-remove fcitx
Purging config data:
sudo apt-get purge --auto-remove fcitx
I met the same problem. I tried piotr.wittchen's solution and it did work, but I couldn't input Chinese any more after that.
So, I reinstalled fcitx, and modified its Global Config in Input Method Configuration. Choose Show Advanced Options, and make Switching Virtual Keyboard empty. This solved the problem for me.
Du Ang
  • 31
You can disable this by below steps: Settings->Fcitx config->Global config->Show advanced Options(Left bottom) -> Switching Virtual Keyboard -> Pressing Esc.
BJDM
