43
I'm trying to unlock my Moto phone using ADB but I when I do a fastboot devices I keep getting
no permissions   fastboot
Even sudo fastboot devices is not helping
with sudo I get this sudo: fastboot: command not found
HELP!!
Rupali
  • 751
9 Answers9
80
Try using sudo $(which fastboot)
for instance sudo $(which fastboot) devices
also sudo $(which fastboot) oem unlock
40
Found a better solution over here:
https://stackoverflow.com/a/28127944/1621927
Here is the comment:
Instead of forcing permissions via sudo each time you need to run fastboot, you can permanently fix the issue:
  1. use lsusb to identify your device USB VendorID
  2. configure udev to set proper permissions when your device is plugged in
  3. profit!
As a bonus - it will be fixed for adb too.
For example, in my case (for 'Megafon SP-A20i') :
$ fastboot devices
$ sudo fastboot devices
[sudo] password for kaa:
MedfieldA9055F28    fastboot
Let's fix:
First, we need to identify the device:
a) look for usb bus number (hack: I know the device is Intel-based one)
$ fastboot -l devices
no permissions         fastboot usb:1-1.2
$ lsusb |grep 001 |grep -i intel
Bus 001 Device 044: ID 8087:09ef Intel Corp.
Bus 001 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
b) look for other Intel devices:
$ lsusb |grep 8087
Bus 002 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
Hubs are not smartphones definetely, so - USB vendorID we need is "8087".
Second, configure udev (you must replace "idVendor" value with yours) :
$ sudo sh -c "echo '# Megafon SP-A20i' >> /etc/udev/rules.d/51-android.rules"
$ sudo sh -c "echo 'SUBSYSTEM==\"usb\", ATTR{idVendor}==\"8087\", MODE=\"0666\", GROUP=\"plugdev\"' >> /etc/udev/rules.d/51-android.rules"
$ sudo service udev restart
udev stop/waiting
udev  start/running, process 1821
Third, re-plug your device to allow udev to perform it's magic.
Final check:
MedfieldA9055F28       fastboot usb:1-1.2
$ adb devices
List of devices attached
$ fastboot reboot
rebooting...
finished. total time: 0.253s
$ sleep 90
$ adb devices
MedfieldA9055F28    device
Voila!
elichai2
  • 691
  • 14
My Solution
Thanks to elichai2 and this link and list I was able to solve my fastboot permission issue.
I have the Google Nexus 6P so I used the following for my Vendor ID:
Google - 18d1
51-android.rules
If you use the following command:
sudo sh -c "echo 'SUBSYSTEM==\"usb\", ATTR{idVendor}==\"8087\" ..."
copy it exactly. I was already root and tried to copy just the echo portion which gave me undesirable results. Basically it put the \" in the .rules file rather than interpreting the slash as the escape character.
I suggest using the following if you already root creating the .rules file (Use your vendor ID).
echo 'SUBSYSTEM=="usb", ATTR{idVendor}=="18d1", MODE="0666", GROUP="plugdev"' >> /etc/udev/rules.d/51-android.rules
Udev Reload and Trigger
I reloaded the udev rules and then issued the trigger command. I also unplugged and plugged the usb for good measure.
udevadm control --reload
udevadm trigger
Fastboot
As an unprivileged user I then ran:
fastboot devices
and it worked as desired. I hope this can be of use or help to anyone that experiences trouble with the permissions issue.
when i need to send some commands using fastboot ( flashing firmware on htc device for example ) i do install fastboot using apt
sudo apt install android-tools-fastboot
then when i start use it first command is
sudo -s
then all commands in this terminal will run as root sending commands like
fastboot devices
fastboot reboot-bootloader
fastboot oem rebootRUU
fastboot flash zip xxxx.zip
no need for fix or something it's simple one extra command before start it
It's a problem with missing udev rules, defined in /lib/udev/rules.d/51-android.rules. Instead of creating udev rules manually (as Brandon Authier suggests), it's just better to install package android-sdk-platform-tools-common which contains it.
apt install android-sdk-platform-tools-common
pevik
  • 483
`$ fastboot devices
no permissions (user in plugdev group; are your udev rules wrong?); see [http://developer.android.com/tools/device.html] fastboot`
`Solution: $lsusb
Bus 003 Device 040: ID 18d1:d00d Google Inc. Android`
sudo sh -c "echo 'SUBSYSTEM=="usb", ATTR{idVendor}=="18d1", MODE="0666", GROUP="plugdev"' >> /etc/udev/rules.d/51-android.rules"
my solution was to use a proper USB-cable. I had 2 cables which had the "no permission" issue, but with the third (good) cable it worked.
Or you can add all the udev rules: Full set of Android USB vendor ID rules for Linux https://gist.github.com/jdamcd/6054951#file-51-android-rules
-1
First install fastboot from apt:
Next execute fastboot with sudo:
sudo fastboot
It works for me.
mrroot5
  • 559
