I already checked here: Trying to do ssh authentication with key files: server refused our key
and I did all these:
*new:
- generated key(s) via ssh-gen in a Linux client.
- added the public key to the server via ssh-copy
now I don't see any error message,
here's ssh -vvv:
http://pastebin.com/Cxspz5P3
Could it be that there's an order to the authentication process, but the server first tries to verify password, instead of trying out the publickey?
Original post: what I tried so far:
generated key(s) via puttygen (v.2015-12-03) in the windows client:
- 2048 bits, and tried also key-pair with 1024 bits
copied "openssh public key" in 1 line format from puttygen,
the line that looks like:
ssh-rsa xxxx... ==pasted it to the ubuntu server to
~/.ssh/authorized_keysone line for the 2048 bit key, additional line for the 1024 bit key
I changed the file permissions like so:
chmod 700 ~/.ssh chmod 600 authorized_keys chmod 700 ~ chown -R $USER.$USER ~/putty session settings:
'connection' > 'data' > 'username' > myuser
'connection' > 'ssh' > 'auth' > the PPK file
tried with both 2048 bit and 1024 keys (with their respective public keys)
tried also from localhost (
ssh -i .ssh/mykey myuser@localhost) – got the same/var/log/autherror:Failed publickey for (myuser) from ::1 port 50087increased log level of
/etc/sshd_config:LogLevel VERBOSE(is there higher value?) on the server, and restarted./var/log/auth.lognow gives:**Failed publickey for** myuser from xx.xx.xx.xx port xx: RSA xx:xx:xx...
systems:
- tried to connect from:
- from windows (putty 2015-12-3, key is PPK)
- from linux/mint 17 (via ssh, openssh key)
- server: Ubuntu 14.04.2 LTS
- keys generated by puttygen on windows (v.2015-12-03)
- also tried with "kitty" (a putty fork)
- ssh with password - works. always.
tail -f /var/log/auth.log isn't showing anything for failed logins, only for successful and for logouts.
Can it be cured?
is there another way to diagnose the problem?
Q&A:
Q. What is a "data" connection? Why didn't you use "ssh" in both cases?
A. it's just the section's name in putty config.
Q. cat /etc/ssh/sshd_config|grep -i author
A. AuthorizedKeysFile ~/.ssh/authorized_keys
Q. ls -lZ .ssh (on the server)
drwx------ 2 myuser myuser ? 4096 Dec 5 12:28 . <---- the .ssh dir
-rw-r--r-- 1 myuser myuser ? 666 Dec 5 12:29 known_hosts
-rw------- 1 myuser myuser ? 1671 Dec 3 12:07 mykey.ssh
-rw------- 1 myuser myuser ? 608 Dec 3 11:47 authorized_keys
