so i'm new to linux and i installed ubuntu 14.04 on my old laptop lenovo g50 - i3 -8gb - radeon graphics and it was working fine for around 5 days and then soon every time i tried to login i got stuck in the login loop. Please help.
Asked
Active
Viewed 458 times
Some steps you can take to fix the login loop:
Go to terminal from login screen: Ctl Alt F1
login with user-name and password.
Run updates "sudo apt-get update"
Check all applications "sudo apt-get upgrade"
Check all packages "sudo apt-get -f install"
Update grub "sudo update-grub"
Remove all old applications and packages "sudo apt-get autoremove"
Reboot "sudo reboot"
DnrDevil
- 1,478
I too have had this problem. I would suggest DnrDevil's answer (updating, removing all old application, etc.) and if that doesn't work, to try the following:
Sometimes, the .Xauthority file doesn't belong to the correct owner (you). To fix it:
- At the login screen enter runlevel 3 by pressing CTRL+ALT+F3
- Type
chown 'username':'username' .Xauthority, replacing the'username'with your username.
If this doesn't work, then I would suggest you follow the first answer at this link: Ubuntu gets stuck in a login loop
I hope this helps!
willem.hill
- 797
