I am running Ubuntu 15.10 with GNOME 3.18, and for some debugging work need to capture IPV6 packets going to and from a specific port, however I understand that by default IPV6 packets are not captured by WireShark, so how can I get WireShark to capture them? And can I also get it to capture both IPV4 and IPV6 packets? I have read this, however this does not seem to explain how to show both IPV6 and IPV4 packets at the same time, only how to filter it so that it only shows IPV6 ones.
OS Information:
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 15.10
Release:    15.10
Codename:   wily
Flavour: GNOME
GNOME Version: 3.18
Package Information:
wireshark:
  Installed: 1.12.7+g7fc8978-1
  Candidate: 1.12.7+g7fc8978-1
  Version table:
 *** 1.12.7+g7fc8978-1 0
        500 http://archive.ubuntu.com/ubuntu/ wily/universe amd64 Packages
        100 /var/lib/dpkg/status
By default, there is nothing that you need to do. Simply select the appropriate interface to capture on, and start capturing. All traffic on that interface will be captured.
To show only ipv6 traffic in the display, you simply enter ipv6 as the filter match.
dobey
  • 41,650
There is nothing in Wireshark to, by default, not capture IPv6 packets. Just try capturing them.
