I have a persistent USB installation of Ubuntu 14.04. Firefox would not play MPeg4, AAC or QuickTime -- so I tried to install the "restricted-extras". The install progress bar went 3/4 to 4/5th of the way and then after a long delay the Window went "dim" and eventually the OS indicated "No Response" from the process.
I tried several times all with the same result - even rebuilding the Ubuntu installation.
Even with the partial installation Firefox would now play videos - but when I went to install Wine and Mono they both would not even start due to missing dependencies. I am suspect of the "fonts" (supposedly to be installed by the package) that they may not be there because the process locked-up and quit, that perhaps Wine and Mono want them but I just don't know and although a professional I am very new to Linux.
Gayan Weerakutti
  • 3,830
  • 28
  • 39
EJE
Open terminal and try
sudo apt-get update
sudo apt-get upgrade
In a terminal, please run:
sudo apt-get install --reinstall ubuntu-restricted-extras
You will see two dialogues popping up in your terminal that require you to accept the EULA (End User License Agreement) of some packages (one of them is ttf-mscorefonts-installer).
Press Tab to select the <OK> or <YES> buttons (will get highlighted with red background) and confirm with Space Bar.
Your GUI installation has probably not finished because it failed to ask you to confirm those two dialogues. The reinstall through the terminal will prompt them to you again and fix the problem.
In case the ttf-mscorefonts-installer fails to download the necessary components, you need to purge this again and install the .deb package in version 3.6 from the Debian server.
Run this command to purge the defect ttf-mscorefonts-installer package:
sudo apt-get purge ttf-mscorefonts-installer
Then either download the newer package for Debian from here and open/install it through the Software Center - or run the following set of commands to do the same through the terminal:
wget -q 'http://ftp.debian.org/debian/pool/contrib/m/msttcorefonts/ttf-mscorefonts-installer_3.6_all.deb'
sudo dpkg -i ttf-mscorefonts-installer_3.6_all.deb
If you want, you may delete the ttf-mscorefonts-installer_3.6_all.deb file again after the successful installation.
The second part of this answer about repairing a broken ttf-mscorefonts-installer is derived from this answer by user AnAwesomeMiner.
Byte Commander
  • 110,243
