-3
I am using infocus m2. I want to transfer some videos from my mobile to my PC.
I am using Ubuntu on my PC. When I connect my mobile to my PC via the USB port the the mobile storage is not shown by Ubuntu.
andy256
  • 229
Many new phones allow access through MTP at best and it might be set to something else by default. So first on your phone look in "settings" for something like "PC connection" and make sure it is on "storage" or "media transfer". If you have a usb storage option we're done here.
Otherwise I think MTP support is provided to Gnome/Nautilus by the "gvfs-backends" package, to install try:
sudo apt-get install gvfs-backends
Then it should just show up as a disk (phone must be unlocked to initially access). Ok were done now right?
As a last resort "adb" can do file transfers. Enable/enter developer options and turn on usb-debugging. Install adb:
sudo apt-get install android-tools-adb
Then the command will be something like (warning: be in the directory you want the files in):
adb pull <path/to/your/file>
Where will be something like "/storage/sdcard0/DCIM/", but this will probably be device specific (pro-tip: you can use "adb shell" to stumble around and find the DCIM directory).
Best of luck.
