From command line, after entering sudo apt-get upgrade I get
WARNING: The following packages cannot be authenticated!
r-cran-matrix
Install these packages without verification [y/N]?
Alternatively, from Task Manager, I get
Many related solutions exist. Trying this one leads to
Reading package lists... Done
W: GPG error: http://cran.rstudio.com precise/ Release: The following signatures were invalid: KEYEXPIRED 1445181253 KEYEXPIRED 1445181253 KEYEXPIRED 1445181253
W: Duplicate sources.list entry http://linux.dropbox.com/ubuntu/ precise/main amd64 Packages (/var/lib/apt/lists/linux.dropbox.com_ubuntu_dists_precise_main_binary-amd64_Packages)
W: Duplicate sources.list entry http://linux.dropbox.com/ubuntu/ precise/main i386 Packages (/var/lib/apt/lists/linux.dropbox.com_ubuntu_dists_precise_main_binary-i386_Packages)
I seem to get an identical set of errors after working through the instructions in this solution.
I also tried this, which led to the following failures at the end of apt-get update:
W: You may want to run apt-get update to correct these problems
What am I missing?
