when i try to install fglrx with synaptic package manager a have the following errors:
Please insert the disk labeled: Ubuntu 14.04.3 LTS Trusty Tahr - Beta amd64 (20150805) in drive /media/cdrom/
firstER secondER
lupu
You have to remove the cdrom entry from the sources.list and you can do this using below syntax:
sudo sed -i '/cdrom/d' /etc/apt/sources.list
then check content
grep -v '#' /etc/apt/sources.list
The solution was to remove the CD-ROM from the Sources List.
Go to System->Aministration->Software sources. Go to Ubuntu Software tab, at the bottom of the tab there is an option for CD/DVD. Selecting/deselecting it enables and disables CD/DVD as software source. Just un-check this option and your system will not look for Ubuntu CD or DVD
https://askubuntu.com/a/42446/477203
lupu
