QtCreator shows me this error message and asks me to browse for and select a cmake executable:
/usr/bin/cmake: error while loading shared libraries: libgssapi_krb5.so.2: cannot open shared object file: No such file or directory
David Foerster
  • 36,890
  • 56
  • 97
  • 151
That error message actually suggests that it is able to find the cmake executable (as /usr/bin/cmake) but when it attempts to execute it it can't, because cmake requires a shared library (libgssapi_krb5.so.2) which can't be found.
There are a variety of ways that that might happen, but there are a couple of things you can try:
If the library is just not actually installed, you may need to install its package:
sudo apt-get install libgssapi-krb5-2
If the libgssapi-krb5-2 package is already installed, it's possible that there is just a problem with the libgssapi_krb5.so.2 symlink that links to the actual library. If this is the case, the following command should fix it:
sudo ldconfig -v
It may also be a good idea to make sure that there aren't any other libraries that are missing that cmake needs to run. You can do this with the following command:
ldd /usr/bin/cmake
This will print all of the shared libraries it needs, and where it found them in the filesystem (if it was able to find them, or tell you if it can't)
Foogod
  • 315
