The Wifi isn't working, I'm not able to create a new (wifi) connection in the Network Settings.
As mentioned in this answer I should ask a new question, if I have PCI ID that's not listed and well sadly I've got one : 14e4:43ae. I'm running the newest version of Ubuntu. uname -r returns 4.2.0-18-generic.
sudo lspci -vnn
02:00.0 Network controller [0280]: Broadcom Corporation Device [14e4:43ae] (rev 02)
    Subsystem: Lenovo Device [17aa:0622]
    Flags: bus master, fast devsel, latency 0, IRG 255
    Memory at d4800000 (64-bit, non-prefetchable) [size=32K]
    Memory at d4400000 (64-bit, non-prefetchable) [size=4M]
    Capabilities: [48] Power Management version 3
    Capabilities: [58] MSI: Enable- Count=1/1 Maskable- 64bit+
    Capabilities: [68] Vendor Specific Information: Len=44 <?>
    Capabilities: [ac] Express Endpoint, MSI 00
    Capabilities: [100] Advanced Error Reporting
    Capabilities: [13c] Device Serial Number 00-00-08-ff-ff-00-30-0e
    Capabilities: [150] Power Budgeting <?>
    Capabilities: [160] Virtual Channel
    Capabilities: [1b0] Latency Tolerance Reporting
    Capabilities: [220] #15
sudo lshw
*pci:1
    description: PCI bridge
    product: Wildcat Point-LP PCI Express Root Port #3
    vendor: Intel Corporation
    description: id: 1c.2
    bus info: pci@0000_00_1c-2
    version: e3
    width: 32 bits
    clock: 33 MHz
    capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
    configuration: driver=pcieport
    resources: irq:18 memory:d4400000-d48fffff
   *-network UNCLAIMED
        description: Network controller
        product: Broadcom Corporation
        vendor: Broadcom Corporation
        physical id: 0
        bus info: pci@0000:02:00.0
        version: 02
        width: 64 bits
        clock: 33MHz
        capabilities: pm msi pciexpress bus_master cap_list
        configuration: latency=0
        resources: memory:d4800000-d4807ffff memory:d4400000-d47fffff
The output of sudo lshw | grep wireless is empty.
EDIT: I'm now really getting annoyed by this Broadcom Chip! Anyway, I ordered an Intel Wifi Chip and I'm going to replace my current with it.
