I'm somewhat new to Ubuntu but have been learning a lot on my own. I am an admin user for my PC. However, when I try to take ownership of most folders, like usr/local, it says I don't have permission and I'm not able to change any permissions. It doesnt make any sense because I'm the only one who uses this PC and I'm an admin. I even tried taking ownership using the terminal with no luck. Any suggestions would be greatly appreciated. I'm also using Ubuntu 14.0
Asked
Active
Viewed 1.0k times
You can change the ownership of files using the chown command. Run man chown to read the documentation. In short, you can use it as sudo chown USERNAME:GROUPNAME file.
BUT:
I would not recommend changing the ownership of file outside your home directory! See Changed owner of /usr/bin and Changed permissions of / to user to see what happens when you do it.
Maybe the extension nautilus-admin could help you a bit to change your settings via a graphical user interface.
