I have a problem with my usb wireless stick (TP-LINK TL-WN821N) when I'm surfing on the net or something like that, so in every ~30 minutes I get disconnected from the internet, unfortunatly whent it happens I always have to unplug and then connect this usb device so that I can connect to the internet again.
ps: under windows it works properly and under the previous version of ubuntu
Braiam
  • 69,112
5 Answers5
I suggest you to do the trick proposed in the comment 13 of this Launchpad bug, that is to blacklist the ar9170usb driver:
https://bugs.launchpad.net/ubuntu/+source/linux-backports-modules-2.6.32/+bug/495562
heiko81
  • 1,925
This seems to be a driver bug. See the official documentation for that card:
And the bug reports in launchpad:
Some fixes / workarounds are described. Disabling the N-thingy seemed to work accoding to this answer:
mario
  • 3,530
I had exactly the same problem with my stick (TP-LINK TL-WN821N V3). After downloading latest network drivers by following this blog entry, it works a lot better:
http://whilesurfing.blogspot.com/2012/02/ubuntu-tp-link-tl821nv3-tl822n-v20.html
ezpn
  • 325
The below link is an correct solution for TL-WN823N / WN821N Driver https://github.com/pvaret/rtl8192cu-fixes/blob/master/README.md
Ok i "solved" the problem by manually configuring wireless! HOW TO: 1) Make a config file like this:
ctrl_interface=/var/run/wpa_supplicant
network={
        ssid="Your_neworkName"
        psk="Password"
        key_mgmt=WPA-PSK
        proto=WPA2
        pairwise=CCMP TKIP
        group=CCMP TKIP
see this for more details how to. And save it to /etc/wpa_supplicant/wpa_conf.conf 2) Disable your network manager:
sudo /etc/init.d/NetworkManager stop
then test your configuration by running:
sudo wpa_supplicant -D wext -i wlan0 -c /etc/wpa_supplicant/wpa_conf.conf
Is everything working? Nice go ahead to step 3)
3) Make a new script on your desktop called connect.sh containing
ifconfig wlan0 down
dhclient -r wlan0
dhclient wlan0
and assure it is runnable.
4) Install "alacarte" (if Ubuntu 11.10) and create a new Launcher in Network Menu:
  • Name: Connnect
  • Command: gksudo /path/to/your/script.sh
  • Description and icon: everything you like.
5)Search for "Connect" on your Dash and drag and drop it to your Dock ;)
6)Everytime you need to connect to your network just launch "Connect app" and it's done.
N.B. You need to configure every wireless network by hand!!! Please contact me if something doesn't work!
Otacon
  • 271
