What I want to do: Whenever the apt-get install command is run and terminates, run another command immediately without any involvement on the user's part. In my case I want to run a script, but since I can substitute a command for that, a command would be preferable as an example.
By the way, I don't want to run a script that executes two commands, since it must then be manually executed, which is not what I want. The termination of the apt-get install command must prompt the execution of another command.
NOTE: This may seem like a duplicate of this question, and while I do have an answer, I want to make my intention clear in case there are any other possible solutions, while also clarifying my requirements to other potential viewers to this question.
Edit:
To clarify: I am trying to get one command that runs two!
Why? I want to generate a file containing a list of all the installed dependencies and software on my distro, which is updated every time the apt-get install command is used.
TellMeWhy
  • 17,964
  • 41
  • 100
  • 142
The hard part is parsing the arguments correctly. You can handle simple apt-get install pkgname cases easily, but as soon as you want to handle apt-get -y install pkgname in addition, you suddenly need a full fledged option parser.
Assuming the simple cases is ok enough, something like this wrapper script may suffice:
#!/bin/bash
/usr/bin/apt-get "$@"
status=$?
if [[ $1 = install ]]; then
    read -rp 'Run this other thing too [Y/n]? ' ans
    if [[ ${ans:-y} = [Yy] ]]; then
        other-thing
        exit # exit with other-thing's exit status.
    fi
fi
exit "$status" # exit with apt-get's exit status.
geirha
  • 47,279
There's couple of ways, depending on your intention.
Sequential execution can me done with ; separator. It will be done in sequence, each command runs regardless for previous command's exit status. Example:
echo hello; printf "\n\n%s" WORLD
Conditional execution can be done with boolean operators || and &&. With these, execution of the second program, depends on the exit status of first (first and second read left to right).
For && the behavior is as such: COMMAND1 && COMMAND2 , if COMMAND1 successfully terminated, COMMAND2 will run. You can remember this as "if left succeeds, the right will run; if left failed, right won't run" [ -f /etc/passwd ] && echo "/etc/passwd exists"
For || it's opposite "If left succeeds, right won't run; if left fails, right will run"
[ -d /etc/passwd ] || echo "/etc/passwd is not a directory"
To put these into one single command, there is couple of options. One obviously is script, but as you requested, you don't want a script. Alternative to that is bash function OR alias.
Bash function is preferred since you can pass arguments to them if you so desire.
In your specific case, you want apt-get install which may take multiple parameters
function installStuff
  apt-get install "$@"
  command2
Place that into your .bashrc, somewhere at the top, close .bashrc and run source .bashrc. Now you have a bash function that always runs apt-get install first, with any number of packages requested, and then immediately command2
Like so
installStuff package1 package2 package3
For conditional running of command2 , use the && and || operators i've already mentioned.
A.B.
  • 92,125
