Motherboard: Asus H170-PRO
CPU: Intel Core i5-6500
HDD: 1TB x2
From the BIOS I made the following changes: AdvancedMode -> Boot -> Secure Boot -> Os Type = Other OS (instead of Windows)
Ez Tuning Wizard -> Created "Super speed raid" with the 2 identical harddisks.
Intel Rapid Storage is ON.
Saved and restarted.
Installed Ubuntu (without errors). I'm using a cd-rom, not a USB key.
Now after grub i get a black screen with white text lines going.. after 2-3 seconds the whole screen is black and stuck here.
EDIT: tried without raid.. same problem :(
EDIT: Tried enabling Legacy BIOS mode and re-installing ubuntu. Now the computer freezes at grub menu.
Ubuntu server 15.10 worked fine. No problems. The only problem is that it's not a LTS version..
nonsensei
  • 103
I encountered the same problem(I also use Asus H170-PRO and 14.04.3 LTS) and solved it by adding nomodeset to the boot parameter. The following post helped me.
How do I set 'nomodeset' after I've already installed Ubuntu?
tfujiki
  • 16
