Are there situations where applications/processes need to be closed before running apt-get dist upgrade?
If so, out of curiosity what happens if you run apt-get dist upgrade anyways, without stopping the application first?
If not, do you need to restart the application after the upgrade?
I'm asking because I have a server running Ubuntu, and I am thinking about having a cron job automatically run apt-get dist upgrade every so often.
Also, it is my understanding that a reboot shouldn't be necessary unless there is a kernel update.
Kevin Wheeler
  • 123
No process in a server environment need to be stopped/closed during an update with the package manager. The installation and removal scripts in /var/lib/dpkg/info start and stop the services for you, if it's necessary. Mostly it's only a reload, e.g.
sudo systemctl reload service_name
or a restart
sudo systemctl restart service_name
A reboot is usually also not necessary. Read this When is it necessary to reboot an Ubuntu system?.
A.B.
  • 92,125
