Everything works fine I just want to know why would my interface change to wlp2s0 by default instead of the usual wlan0
A new naming scheme has been introduced, to solve problems that arose from the old (eth0, wlan0) naming standards.
Here is a short introduction and explanation of the concept: http://www.freedesktop.org/wiki/Software/systemd/PredictableNetworkInterfaceNames/
Basically, the first two letter describe the type of interface. 'wl' for wlan, 'en' for ethernet. The following code is often a description of the physical placement of the device in your computer - p2 is likely PCI bus 2, and s0 is likely slot 0.
As kyodake pointed out, this new standard was introduced when Ubuntu moved to systemd.
- 1,165
- 828
Why Ubuntu with systemd have added native support for a number of different naming policies into systemd/udevd proper and made a scheme similar to biosdevname's the default. The following different naming schemes for network interfaces are now supported by udev natively:
(1) Names incorporating Firmware/BIOS provided index numbers for on-board devices (example: eno1)
(2) Names incorporating Firmware/BIOS provided PCI Express hotplug slot index numbers (example: ens1)
(3) Names incorporating physical/geographical location of the connector of the hardware (example: enp2s0)
(4) Names incorporating the interfaces's MAC address (example: enx78e7d1ea46da)
(5) Classic, unpredictable kernel-native ethX naming (example: eth0)
By default, systemd will now name interfaces following policy:
(1) if that information from the firmware is applicable and available, falling back to:
(2) if that information from the firmware is applicable and available, falling back to:
(3) if applicable, falling back to:
(5) in all other cases.
Policy (4) is not used by default, but is available if the user chooses so.
- 17,808
