I run a small Minecraft server on an Ubuntu PC in my house. Sometimes I have to manage the server outside of my home so I use an ssh client on my phone. This works, but each time I close the app and then relaunch I have to create a new terminal session. How can I toggle to the existing one?
Asked
Active
Viewed 137 times
I suggest you install and keep screen running. It's a terminal multiplexer, in other words - terminal session splitter.
You have to have multiuser mode enabled to that you can attach to that session. So inside the terminal on the server, press Ctrl+a , then immediately Shift+;. The bottom of the screen will highlight and you will see a semicolon there. Type in multiuser on.
Now, from another computer you can SSH into your server, and type in screen -ls to know the title of the session. Example:
xieerqi:$ screen -ls
There is a screen on:
4704.pts-5.eagle (11/24/2015 01:23:04 AM) (Multi, attached)
Type in screen -x sessionTitle to attach. Example:
screen -x 4704.pts-5.eagle
Now you're back to the existing session.
To detach, use Ctrl+A, followed by d
A.B.
- 92,125
Sergiy Kolodyazhnyy
- 107,582
