I just installed Ubuntu 15.10 and after login, i do have only the new wallpaper, I do only have that, no menus, no interface, nothing...
I see the login screen, once I log in, just the wallpaper. If i connect a USB the explorer opens and I can see all the folders, including the root.
Any suggestion?
UPDATE:
  • I have tried to reinstall, reset, remove and install both Ubuntu-desktop and unity fully and no solutions.
  • I have tried to activate the unity plugin. (was already activated).
  • I have tried to reset the user files.
  • tried to reinstall everything (.iso and OS).
None of those worked for me.
By-Jokese
  • 111
I had this same issue on my desktop computer, with Ubuntu 14.04 I found that problem is with the graphics incompatibility. Are you using and graphics cards and any 3rd party graphics driver?
Try to unplug it and then reinstall..if it will not work then try some other light weight desktop environment..I presume your Xorg file is the main culprit
