Ubuntu 14.04LTS. Set to suspend when lid closed.
Mostly it works - often I can use it for a week, suspending and resuming with no problems. But sometimes something changes and it stops working: shutting the lid will do nothing - the machine keeps running.
If the fan comes on then I know it has happened. Otherwise the first I know about it is when I open it the next day and the battery is completely flat, or if I open the lid a short while later and notice it's still running.
Rebooting always solves it - meaning that it will now suspend and resume happily again - but I have not found any less severe way to recover the situation. I also don't know what to do to force the problem.
I have found many questions about suspend not working at all - but that's not the problem here.
Is there anything I can do to diagnose please?
Mark Smith
  • 1,313
  • 24
I'm having a similar issue. I didn't identify the source yet, but here's what I did
1-Ran dmesg and captured the time of the last event. 2-Ran dmesg | grep "{last event time}" -A1000 to capture the lines. You should get only 1 line. 3-Closed the lid.
In my case, it tries to suspend, and it wakes up itself almost immediately.
4-Opened the lid, unlocked the screen and ran again the last dmesg with the grep.
I saw in the output the computer is going to sleep, and immediately wakes up itself, on it's own.
I guess there's something like laptop-tools or similar waking it up. I removed the USB devices as well, and it keeps waking up.
I will let you know if I manage to find the solution. I'm using a Thinkpad T430S here.
Best!
