I have a Windows 7 (originally) Laptop that I deleted the Windows OS and opted for the full Ubuntu hard install. Everything went fine, however Ubuntu will not boot from the HDD. I went into Bios and set my boot order to boot the HDD first. Still wont boot. I can get into the Grub, however (dont tease me, haha) I am a Noob with Linux and computers in general so I have no idea how to use the grub or command prompt. What are some tips or command line entry to get whatever I need (like a graphics driver or something) to start this sucker up? I should mention that I can load the DVD that has the Ubuntu install and boot it up if I "try Ubuntu without installing" option.
Do you get any errors when trying to boot Ubuntu from HDD?
Copy paste solution from this link:
Try re-installing the Grub bootloader again. To do that use your live USB and >boot into Ubuntu 14.04 and install boot-repair with the following commands:
sudo add-apt-repository -y ppa:yannubuntu/boot-repair && sudo apt-get update
sudo apt-get install -y boot-repair && boot-repairUse advanced options(at left bottom) in boot-repair(not the recommended).Open advanced options in boot-repair .
advanced options=>'GRUB location'(Select "place grub into". Select "sda". >Don't select sda1 or sda2 or anything like those numbered partitions. Just >choose 'sda' only)
advanced options=>'GRUB options'(Select "Purge grub before reinstalling it")
advanced options=> Other options( Unselect the "Repair Windows boot files" & >"Check Internet connection" if they are selected.)
