I have the problem that when I open some programs/documents in Gnome, the wrong application is launched to open these.
I think I already narrowed the problem, that everything that is called with file:// will be launched with the wrong program (in my case keepassx). I remember that when everything starts, I wanted to start keepassx from my gnome-panel. Ubuntu asked me with what program it should be started. I wondered a little, since I used it already a lot, so I choosed keepassx from the list. But it seems that this has overriden the file-protocol handler.
Some situations where the wrong program is called: shortcuts in my gnome panel (personal folder - which should open nautilus, keepassx, some txt files), synapse (launcher like gnome-do) and firefox finished downloads.
How can I reset this setting to get everything back to normal?
Edit:
The only reliable way to open files currently is via nautilus.
To give an example, a shortcut in the gnome-panel has the following properties: Name: myfile.txt, Location: file:///home/dag/myfile.txt, Comment: »/home/dag/myfile.txt« öffnen
I use Ubuntu 11.04 with "Gnome-classic" aka Gnome2 2.32.1
Dag
  • 65
There are a few places I can think of looking. I'm not entirely sure how you got in this situation, so I'm not sure which is likeliest:
  1. ~/.local/share/applications/defaults.list (see if you have anything suspicious in there)
  2. ~/.local/share/applications/mimeapps.list (likewise)
  3. Run gconf-editor, navigate to /desktop/gnome/url-handlers, and see if you have a file subdirectory in there.
Do any of those help?
The easiest solution is right click to the file/properties/open with (tab) and select the program you want to use. Maybe you can try too with Ubuntu Tweak to manage the file associations.
