I want to make uget as a startup application in ubuntu. I am unable to understand how to add uget to startup application preferences as I cannot find its command. Please help.
The command to run uGet is:
uget-gtk
To find the command to run a (globally installed) application, simply look into its .desktop file in /usr/share/applications, and look for the first line, starting with Exec=.
In this case, the file is /usr/share/applications/uget-gtk.desktop. To open the file with gedit, drag it over an opened gedit window.
Alternatively
to find the (complete) command, you can make an "educated guess" on what the command should start with, in this case, typing:
uget + Tab
will complete the command into:
uget-gtk
Adding it to Startup Applications
This part you probably already know, but to be complete:
Open Dash > Startup Applications, click on the "Add" button, add the command uget-gtk
- 85,475
If you use Linux mint 19.1 Cinnamon, you can easily add uGet as Startup Application. Just search in the menu.
- 1
