Is it possible to view recently accessed files using a single command in the command-line?
Could you please provide an explanation of what exactly the command does?
My "recently" is 5 minutes =)
recently=5
find . -type f -amin "$recently"
Breakdown
find
search for files in a directory hierarchy
search in the current folder and all subfolders
-type f
search only fort files
-amin 5
File was last accessed 5 minutes ago.
Or perhaps you mean the recently used files in your Desktop Environment, than you need something like
awk -F"file://|\" " '/file:\/\// {print $2}' ~/.local/share/recently-used.xbel
Breakdown
awk
pattern scanning and text processing language
-F"file://|\" "
define two field separators, file:// and "
/file:\/\//
only lines with file:// are interesting
{print $2}
the path is in column 2
The term recently is relative, I am going to assume last 10 minutes as recent in my answer (change that to fit your need).
Using find:
find . -type f -amin -10
Here the -amin -10 would find all files (-type f) in the current directory and all subdirectories accessed within last 10 minutes.
For files accessed less than 30 minutes ago:
find . -type f -amin -30
Using zsh:
print -l **/*(.am-10)
**/* looks recursively for files and the glob qualifier (.am-10) finds files (.) accessed within the last 10 minutes (am-10).
