I am attempting to return all column values from an Sqlite db to a Qchart in qml in Ubuntu SDK - the db contains various fields including kilometres, miles, etc. I would like to return all values in one field (e.g. kilometres) into the Qchart - I know that this is possible using an array, e.g.
function testData(){
var kilometres = ["25","45","42","39"];
    return kilometres;
this will happily display the values 25,45,42 & 39 in the chart. However, try as I might, I cannot find a way to pass the values contained in the database to the array shown above. The following is what I have tried so far:-
// Chart Data
function getData() {
    var db = LocalStorage.openDatabaseSync("data.sql", "1.0",  "mileageDataBase", 10000000);
    var res = "";
    db.transaction(
    function(tx) {
    var rs = tx.executeSql('SELECT kilometres FROM mpg');
    res = rs.rows.item().kilometres;
 return res;
(Please note that an earlier version of this question I asked about returning values to a TextField. I thought I could use this TextField to populate the graph but, after some experimentation, that does not appear to be the case. Apologies for the confusion.)
Finally managed to get it to work :-). I'm posting my (working) code here in case anyone else hits a similar problem:
// Chart Data
var ret;
var res = [];
var index;
db.transaction(
   function(tx) {
   var rs = tx.executeSql('SELECT * FROM mpg');
   for (var i=0; i<rs.rows.length; i++) {
   var row = rs.rows.item(i);
   ret = row.miles/row.gallons;
   res.push(ret);
return res;
Many thanks to Velkan for helping to point me in the right direction (even though the original question was more than a little ambiguous :-) )
