I have dual booted Windows 10 along with Ubuntu. It is an efi system.
Now, I want to remove Ubuntu. Firstly, I removed the partition then I tried to remove grub by using Windows installation disk. But it wasn't successful. I also tried to remove efi folder and wasn't successful at this also.
I still have a GRUB2 command line while booting.
Please suggest on removing this option.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
Although we are way more interested in helping people that are using or want to use Ubuntu ...
Boot from Ubuntu installation media and select Try Ubuntu without installing.
When the desktop appears, open a terminal (Ctrl+Alt+T) and execute:
sudo mount /dev/sd* /mnt
sudo rm -rf /mnt/EFI/ubuntu
Note: * = EFI partition
You can identify the EFI partition with GParted, which is included in the installation media.
cl-netbox
  • 31,491
You should boot windows recovery mode -> insert your windows pwd -> troubleshooting -> advanced options -> fix problems that prevent windows from booting properly (it's my translation, since I found a solution for your problem but it's in italian) here's the link
It's in italian but you figure it out what to do by watching the pictures. Have a try.
