Boot Info Script e7fc706 + Boot-Repair extra info [Boot-Info 9Feb2015]
============================= Boot Info Summary: ===============================
=> No boot loader is installed in the MBR of /dev/sda.
=> No known boot loader is installed in the MBR of /dev/sdb.
sda1: __________________________________________________________________________
File system: vfat
Boot sector type: FAT32
Boot sector info: No errors found in the Boot Parameter Block.
Operating System:
Boot files: /EFI/Boot/bootx64.efi /EFI/ubuntu/MokManager.efi
/EFI/ubuntu/grubx64.efi /EFI/ubuntu/shimx64.efi
sda2: __________________________________________________________________________
File system: ext4
Boot sector type: -
Boot sector info:
Operating System: Ubuntu 14.04 LTS
Boot files: /boot/grub/grub.cfg /etc/fstab
sda3: __________________________________________________________________________
File system: swap
Boot sector type: -
Boot sector info:
sdb1: __________________________________________________________________________
File system: iso9660
Boot sector type: Unknown
Boot sector info:
Mounting failed: mount: /dev/sdb1 already mounted or /mnt/BootInfo/sdb1 busy
sdb2: __________________________________________________________________________
File system: vfat
Boot sector type: FAT16
Boot sector info: According to the info in the boot sector, sdb2 starts
at sector 0. But according to the info from fdisk,
sdb2 starts at sector 1954316. According to the info
in the boot sector, sdb2 has 0 sectors.
mount: /dev/sdb2 already mounted or /mnt/BootInfo/sdb2 busy
Asked
Active
Viewed 123 times
Byte Commander
- 110,243
There is no Windows installation to be found on your disk as shown in your post.
This is the reason why the GRUB boot menu doesn't have a Windows menu entry.
Maybe you selected to use the whole disk for Ubuntu when you installed Ubuntu.
You may see a BIOS entry because /EFI/Boot/bootx64.efi is still present on sda1.
When you want to have Windows back you unfortunately will have to reinstall it.
cl-netbox
- 31,491
As cl-netbox suggested, you probably wiped windows. If you can see the windows entry in the boot menu try accessing it from there. If it doesn't boot, then it is a confirmation.
