I can't install vlc player on my Ubuntu(14.04). I have read this and try to run the commands, but while I run this command:
sudo apt-get install vlc
I got something like this:
    Reading package lists... Done
Building dependency tree
 vlc : Depends: vlc-nox (= 2.1.4+git20150226+r54594+19+11~ubuntu14.04.1) but 2.1.6-0ubuntu14.04.1 is to be installed
       Recommends: vlc-plugin-notify (= 2.1.4+git20150226+r54594+19+11~ubuntu14.04.1) but 2.1.6-0ubuntu14.04.1 is to be installed
       Recommends: vlc-plugin-pulse (= 2.1.4+git20150226+r54594+19+11~ubuntu14.04.1) but 2.1.6-0ubuntu14.04.1 is to be installed
What is the problem? Have you any Idea to solve this or Could you please tell me the right procedure by which I can install vlc media player?
Update:
After removing the PPA, this is the output of apt-cache policy vlc:
vlc:
  Installed:  (none)
  Candidate:  2.1.2-2build2
    Version table:
      2.1.6-0ubuntu14.04.1 0
        100 /var/lib/dpkg/status
      2.1.2-2build2 0
        500 archive.ubuntu.com/ubuntu trusty/universe i386 Packages
      2.0.1-4 0
        500 archive.ubuntu.com/ubuntu precise/universe i386 Packages
And The command:
apt-cache policy vlc-nox vlc-plugin-notify vlc-plugin-pulse
gives me the following results:
vlc-nox:
  Installed: 2.1.6-0ubuntu14.04.1
  Candidate: 2.1.6-0ubuntu14.04.1
  Version table:
 *** 2.1.6-0ubuntu14.04.1 0
     2.1.2-2build2 0
        500 http://archive.ubuntu.com/ubuntu/ trusty/universe i386 Packages
     2.0.1-4 0
        500 http://archive.ubuntu.com/ubuntu/ precise/universe i386 Packages
vlc-plugin-notify:
  Version table:
     2.1.2-2build2 0
     2.0.1-4 0
vlc-plugin-pulse:
  Version table:
     2.1.2-2build2 0
     2.0.1-4 0
Don't use the PPA, install vlc from the Ubuntu repositories.
  1. Remove the PPA you have installed:
    sudo add-apt-repository --remove ppa:videolan/stable-daily
  2. Empty the package cache:
    sudo apt-get clean
  3. Update your package lists:
    sudo apt-get update
  4. Downgrade/install all vlc packages to/in the repository version:
    sudo apt-get install --reinstall vlc=2.1.2-2build2 vlc-data=2.1.2-2build2 vlc-nox=2.1.2-2build2 vlc-plugin-notify=2.1.2-2build2 vlc-plugin-pulse=2.1.2-2build2
Depending on your Ubuntu version, you might currently (Nov 20, 2015) get a VLC version up to 2.2.1-3 on Wily (15.10). Older Ubuntu versions might have older VLC versions in their repositories.
You check the versions available for you with the command:
An example output on my 15.10 64bit system would be:
vlc:
  Installed: (none)
  Candidate: 2.2.1-3
  Version table:
     2.2.1-3 0
        500 http://[YOUR REPOSITORY SERVER URL]/ wily/universe amd64 Packages
Byte Commander
  • 110,243
