Initially, I had a problem with creating a site within FileZilla as I needed to use a private key to log in to the server, but there wasn't any option listed for logging in with a keyfile. As per this answer I was able to add a keyfile, but I noticed that the site that I created originally hadn't been saved. When I went to create another site, I figured that I just needed to use "normal" as the authentication type, but after selecting "ok", the type changed to "ask for password" for some reason.
The problem is that I don't have the keyfile associated with that site, even though the keyfile is stored in the system so when I log back in, it still asks me for my password. Given that I'm having to retroactively add the keyfile, how can I associate the keyfile with each site that I create?
Sorry, the previously mentioned is not true. I was too naive that things can work out together.
In FileZilla you have to add the key using, menu EditPreferencesSFTP, as you did. Or make sure the key is in your ssh-agent before starting FileZilla (ssh-add -l should list the key).
You account in Site Manager has to have the "Normal" logon type with an empty password and the key should be tried automatically.
Jakuje
  • 6,793
