I have a laptop Asus N55SF with Nvidia GeForce GT555M.
I'm using LG monitor with HDMI. When I installed 14.04 in first time it worked fine, both were enabled at the same time.
Then after some build update for nvidia driver at 331 - they just stop working together. How this happens: - when I boot and see login screen - both are fine - when I login I see 1 desktop stretched into 2 displays and can't click anywhere with mouse, because mouse position is wrong.
I can turn one monitor off with hardware buttons on my laptop and they works fine if one off them is off in the settings. But once I try to switch dual mode - all is stretched again and I need to wait the timeout to restore screens.
Does anyone had same problems?
mr. ap
Finally I found the solution! Just found correct keywords for this in google. Big thanks to "bummi":
nvidia-prime extended desktop stopped working
Will duplicate it here:
Francisco Gouveia (fgouveia87) wrote on 2015-03-10:
After days lost with replacing NVidia drivers and manually editing xorg.conf file, I finally found this!
Rockwalrus (rockwalrus) solution works!
  • On CompizConfig Settings Manager, go to "General Options", then "Display Settings" and do the following:
  • Uncheck "Deteck Outputs"
In the Outputs array, set the resolutions of each of your screens. The >numbers after the resolution "1920x1080+0+0" are the offset. It's important to add this offset according to your needs. I have two full HD screens, so I added the following configuration: 1920x1080+0+0 1920x1080+1920+0 The second output has an offset of 1920, because it is on the right side of the first output, which has a width of 1920.
You will need to install compiz settings manager as well:
sudo apt-get install compiz compiz-plugins compizconfig-settings-manager
mr. ap
