I'm trying to install libqt4-core, but it seems that for the dependencies, I have more recent versions than are compatible with this package. When I use sudo apt-get install libqt4-core my output is as follows:
user@computer:~/torch$ sudo apt-get install libqt4-core
Reading package lists... Done
Building dependency tree
 libqt4-core : Depends: libqt4-dbus (= 4:4.8.5+git192-g085f851+dfsg-2ubuntu4) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed
               Depends: libqt4-network (= 4:4.8.5+git192-g085f851+dfsg-2ubuntu4) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed
               Depends: libqt4-script (= 4:4.8.5+git192-g085f851+dfsg-2ubuntu4) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed
               Depends: libqt4-test (= 4:4.8.5+git192-g085f851+dfsg-2ubuntu4) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed
               Depends: libqt4-xml (= 4:4.8.5+git192-g085f851+dfsg-2ubuntu4) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed
               Depends: libqtcore4 (= 4:4.8.5+git192-g085f851+dfsg-2ubuntu4) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed
I tried doing sudo apt-get install libqt4-core=4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 instead in the hopes that this would be compatible with the packages I have installed already, but apt said it didn't find this version.
I also tried uninstalling the dependencies and re-installing them with the older versions, but the dependencies in turn have more dependencies which conflict because they have the newer version number too. I don't think following this all the way down is a good idea, so I stopped. If there was an option to force everything to downgrade to debian version 2ubuntu4 instead of 2ubuntu4.1 that seems like that should fix this.
How can I get this installed?
(cross-post from SO since I realized this is a better place to post this question)
Edit:
Output of uname -a ; lsb_release -rc ; apt-cache showpkg libqt4-core included as information now:
Linux user-asus 3.13.0-68-generic #111-Ubuntu SMP Fri Nov 6 18:17:06 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
Release:    14.04
Codename:   trusty
Package: libqt4-core
Versions:
4:4.8.5+git192-g085f851+dfsg-2ubuntu4 (/var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_trusty_universe_binary-amd64_Packages)
 Description Language:
                 File: /var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_trusty_universe_binary-amd64_Packages
                  MD5: f8482ce645d26d9ce978ee864c190ae7
 Description Language: en
                 File: /var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_trusty_universe_i18n_Translation-en
Reverse Depends:
  debathena-thirdparty-libraries,libqt4-core
  debathena-thirdparty,libqt4-core
  libqt4-core:i386,libqt4-core
  chessx,libqt4-core
Dependencies:
4:4.8.5+git192-g085f851+dfsg-2ubuntu4 - libqt4-dbus (5 4:4.8.5+git192-g085f851+dfsg-2ubuntu4) libqt4-network (5 4:4.8.5+git192-g085f851+dfsg-2ubuntu4) libqt4-script (5 4:4.8.5+git192-g085f851+dfsg-2ubuntu4) libqt4-test (5 4:4.8.5+git192-g085f851+dfsg-2ubuntu4) libqt4-xml (5 4:4.8.5+git192-g085f851+dfsg-2ubuntu4) libqtcore4 (5 4:4.8.5+git192-g085f851+dfsg-2ubuntu4) libqt4-core:i386 (0 (null))
Provides:
Reverse Provides:
Edit2:
More additional information
sudo aptitude install libqtcore4 libqt4-xml libqt4-test libqt4-script libqt4-network libqt4-dbus
No packages will be installed, upgraded, or removed.
0 packages upgraded, 0 newly installed, 0 to remove and 6 not upgraded.
Need to get 0 B of archives. After unpacking 0 B will be used.
sudo aptitude install libqt4-core
The following NEW packages will be installed:
  libqt4-core{b}
0 packages upgraded, 1 newly installed, 0 to remove and 6 not upgraded.
Need to get 6,354 B of archives. After unpacking 133 kB will be used.
 libqt4-core : Depends: libqt4-dbus (= 4:4.8.5+git192-g085f851+dfsg-2ubuntu4) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is installed.
               Depends: libqt4-network (= 4:4.8.5+git192-g085f851+dfsg-2ubuntu4) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is installed.
               Depends: libqt4-script (= 4:4.8.5+git192-g085f851+dfsg-2ubuntu4) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is installed.
               Depends: libqt4-test (= 4:4.8.5+git192-g085f851+dfsg-2ubuntu4) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is installed.
               Depends: libqt4-xml (= 4:4.8.5+git192-g085f851+dfsg-2ubuntu4) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is installed.
               Depends: libqtcore4 (= 4:4.8.5+git192-g085f851+dfsg-2ubuntu4) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is installed.
The following actions will resolve these dependencies:
     Keep the following packages at their current version:
1)     libqt4-core [Not Installed]
Accept this solution? [Y/n/q/?] q
Abandoning all efforts to resolve these dependencies.
Abort.
Edit3:
Output of apt-cache policy libqt4-core libqtcore4 libqt4-xml libqt4-test libqt4-script libqt4-network libqt4-dbus
user.dz
  • 49,176
  1. Go to Settings → Softwares & Updates
  2. On Ubuntu Software tab: Enable universe component
  3. On Updates tab: Enable trusty-security & trusty-updates
  4. Close & Reload
  5. sudo apt-get install libqt4-core
As you can see here from apt-cache policy output:
libqt4-core:
  Installed: (none)
  Candidate: 4:4.8.5+git192-g085f851+dfsg-2ubuntu4
  Version table:
     4:4.8.5+git192-g085f851+dfsg-2ubuntu4 0
        500 http://archive.ubuntu.com/ubuntu/ trusty/universe amd64 Packages
libqtcore4:
  Installed: 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1
  Candidate: 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1
  Version table:
 *** 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 0
        500 http://us.archive.ubuntu.com/ubuntu/ trusty-updates/main amd64 Packages
        500 http://security.ubuntu.com/ubuntu/ trusty-security/main amd64 Packages
        100 /var/lib/dpkg/status
        500 http://us.archive.ubuntu.com/ubuntu/ trusty/main amd64 Packages
  • This should be reported as a bug. libqt4-core is uploaded as universe, but all its dependences as main. All these packages are from same source packages, they should be uploaded under same component. See http://packages.ubuntu.com/source/trusty/qt4-x11
  • You have trusty-updates enabled for main but not for universe.
All dependencies are installed with version 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 from trusty-update/main. And the corresponding libqt4-core with same version is in trusty-update/universe.
You may try disable universe, trusty-security & trusty-updates close the window without reloading then open it again and enable them. Or enable them manually by editing /etc/apt/sources.list.
user.dz
  • 49,176
