I can't tell if OverlayFS is an actual filesystem I need to create on
the disk images with mkfs -t xxx /path/to/raw/disk/image, or is a
special mounting method and the raw disk images are actually using
something like ext4, but they are mounted in a special way with mount
-t OverlayFS?
One does not need to run any mkfs command for overlayFS, it is just a way of mounting.
Once mounted I believe that I should still be able to see my already
existing files and any files I now create will actually be stored
inside the filesystem1.img file that I could possibly move to another
system?
Yes, for a more detailed explanation of how OverlayFS works, you may wish to refer to "Docker and OverlayFS in practice".
Examples
Creating an overlay mount can be done purely with directories if desired as demonstrated here:
cd /tmp
mkdir lower upper workdir overlay
sudo mount -t overlay -o \
lowerdir=/tmp/lower,\
upperdir=/tmp/upper,\
workdir=/tmp/workdir \
none /tmp/overlay
You can throw in [virtual] block devices with their own filesystems (of any kind) to act as the lower and upper filesystems if you desire. The only restriction is that the "workdir" needs to be an empty directory within the same filesystem as the upperdir. An example using a filesystem for both the upperdir and lowerdir can be shown below:
cd /tmp
# Create the necessary directories.
mkdir lower upper overlay
# Lets create a fake block device to hold our "lower" filesystem
dd if=/dev/zero of=lower-fs.img bs=4096 count=102400
dd if=/dev/zero of=upper-fs.img bs=4096 count=102400
# Give this block device an ext4 filesystem.
mkfs -t ext4 lower-fs.img
mkfs -t ext4 upper-fs.img
# Mount the filesystem we just created and give it a file
sudo mount lower-fs.img /tmp/lower
sudo chown $USER:$USER /tmp/lower
echo "hello world" >> /tmp/lower/lower-file.txt
# Remount the lower filesystem as read only just for giggles
sudo mount -o remount,ro lower-fs.img /tmp/lower
# Mount the upper filesystem
sudo mount upper-fs.img /tmp/upper
sudo chown $USER:$USER /tmp/upper
# Create the workdir in the upper filesystem and the
# directory in the upper filesystem that will act as the upper
# directory (they both have to be in the same filesystem)
mkdir /tmp/upper/upper
mkdir /tmp/upper/workdir
# Create our overlayfs mount
upperdir=/tmp/upper/upper,\
workdir=/tmp/upper/workdir \
none /tmp/overlay
The examples above are taken from my blog post on using overlayfs.
Nesting OverlayFS
... another raw disk image and mount this one on top of the other
one we just created. Do I do this as a second mount command that is
executed after mount command we ran in the previous example, or can I
possibly specify both mounts in one go?
You can nest overlayFS. For example, you can nest the example above as the lowerdir to another overlayFS system by running:
mkdir -p /tmp/upperdir2/upper /tmp/upperdir2/workdir /tmp/overlay2
lowerdir=/tmp/overlay,\
upperdir=/tmp/upperdir2/upper,\
workdir=/tmp/upperdir2/workdir \
none /tmp/overlay2
When Ubuntu gets kernel 4.0+, we should be able to combine multiple lower directories in a single command by using the colon character as a separator like so:
lowerdir=/tmp/lower:/tmp/lowest,\
none /tmp/overlay
In this case, you do not have two workdirs but one, and you keep the same merged path of /tmp/overlay. The lower directories will be stacked from right to left. You can also omit upperdir= entirely, which results in a readonly mount.
